Character dining number
Started by Witters87, August 03, 2016, 02:03:55 PM
Witters87
Hi
I've just tried ringing to reserve a table and my mobile says I can't be connected to this number, has anyone got the correct number I can ring?
The number I tried is 00 33 1 60 30 40 50
Thanks xx
MattR
The french number is +33 (0) 1 60 30 60 30.
twigs72
Strange that the 00 33 160 30 40 50 doesn't get through as that is the number that is on their website. I haven't tried it but will try both numbers when I do my reservations.
twigs72
You can also use 0800 085 0671 which gest you to the reservations, just used this number and made my reservations. ;D
GAVINSM
We went to Inventions on the 4th and Cafe Mickey on the 6th for Character Dining, it was the same basic characters at both.  Except Inventions had Pinocchio and Geppetto as well.
