Marceline
Disneyland Paris phased re-opening from 15th July 2020. See the latest official updates
ADVERTISEMENT - LOGIN OR REGISTER TO HIDE
Brave Roller Coaster - la légende de mor'du
Author Topic: Brave Roller Coaster - la légende de mor'du  (Read 2109 times)
orsie
  • Zip-A-Dee-Doo-Dah
« on: August 30, 2012, 06:44:48 PM »
Hi guys! I've been thinking about this for a while now and I finally decided to post it on here. This coaster would be themed to Brave and called - la légende de mor'du (The Legend Of Mor'du (sounds best in French!)). It would be a little like Expedition Everest but with some notable differences. From the station you will travel up the side of a big green hill (which has the lift hill on it) and when you get to the top you will turn right and then in front of you would be a straight piece of track which flies of the side of the hill and has been broken (like Everest). You will move forward slightly until you reach the end, your car will then click into place and after a few seconds the track will quickly tilt forward (simillar to thirteen but tilting not dropping). The brakes will then release and you will fly through the rubble into the ruins (see movie). After a short downhill through darkness you will arrive into the ruins themselves where you will brake again. Suddenly a Mor'du animatronic will appear and tilt over the cart. It will then fly backwards downhill through darkness and then there will then be a turn. The cart will then stop inside another ruin and the track will spin (so facing forwards) and then plunge once again until back at the beginning. The cars will have onboard speakers playing select bits of the Brave score. Hope you enjoyed my idea!
« Last Edit: January 01, 1970, 01:00:00 AM by Guest »
Previous Disney Trips
DLRP 2007 Sequoia Lodge (15th Anniversary)
DLRP 2008 Sequoia Lodge (15th Anniversary Extended)
DLRP 2009 Sequoia Lodge (Mickey\'s Magical Party)
DLRP 2011 Sequoia Lodge (Magical Moments Festival)
DLRP 2012 Sequoia Lodge (20th Anniversary)
DLRP 2013 Sequoia Lodge (20th Anniversary Extended)
DisneyManiac
  • Substitutiary Locomotion
  • Wannabe Bellhop
Re: Brave Roller Coaster - la légende de mor'du
« Reply #1 on: September 04, 2012, 08:56:02 PM »
Not bad! I am not a Brave fan but I like the sound the ride!
orsie
  • Zip-A-Dee-Doo-Dah
« Reply #2 on: September 05, 2012, 09:00:26 AM »
Thank You!
DisneyManiac
  • Wannabe Bellhop
« Reply #3 on: September 05, 2012, 09:05:50 PM »
No Problem! See if you can recreate it on RCT3!
orsie
  • Zip-A-Dee-Doo-Dah
« Reply #4 on: September 06, 2012, 08:00:53 AM »
I would but there are no elements for tilting and going backwards!
