I have an Imagineering idea. Correct me if I'm wrong, but I don't think this has been done yet in a theme park...
What's the biggest problem with movie-based attractions, such as HISTA, CineMagique, Timekeeper, etc? The answer is, they're always the same. Once you've seen the movie once, there isn't a great need to see it again, 'cos your experience will be exactly the same. Right?
A lot of regular multiplex cinemas are NOW starting to use digital projectors, while the majority of movie-based theme park attractions are still using traditional film projectors. The benefit of using digltal projectors, other than the improved picture quality, is that they can project ANYTHING. By that I mean, they aren't limited to showing what's on a fixed, pre-recorded film strip. They can show live video footage, they can show real-time computer animation, and they can show something different every time.
The part where this gets interesting is, rather than a movie-based attraction being identical every time you see it, imagine if certain sections were different? Imagine if they had several alternative versions of certain scenes, with one version being chosen at random for your screening.
Just imagine how cool this technology would be in an attraction like CineMagique. You know the part where Martin Short steps on his coat, over the puddle? Once you've seen the movie once, you know exactly what's going to happen. Every time he steps on his coat, he's going to fall straight through that puddle. Well, not if that was just one of three possible options. For example:
- Option 1: He falls straight through the puddle
- Option 2: He steps on his coat, and trips on it, falling over in the puddle
- Option 3: He steps on his coat, everythings fine, but then a lorry drives through another puddle and soaks him
So, every time you see the movie, something different happens, which makes the experience more exciting. You don't know and can't predict what's going to happen. Each showing is diffferent, randomised and will surprise you.
Keywords: Randomised Film Concept, Randomized Film Concept
