Marceline
Disneyland Paris is temporarily closed due to the global coronavirus pandemic. See the latest official updates
ADVERTISEMENT - LOGIN OR REGISTER TO HIDE
Disabilities at WDW
Author Topic: Disabilities at WDW  (Read 1545 times)
twentythingamabobs
  • Zip-A-Dee-Doo-Dah
Disabilities at WDW
« on: March 03, 2015, 04:21:04 PM »
Hi all,
Has anyone any experience of travelling to WDW with a disabled guest? I know the EAC does not work the same way over there in that you have to book times for attractions instead of going on the exit. Was wondering how this had worked out for people as I can imagine it can get quite stressful trying to keep track of times for everything. Hoping someone can put my fears to rest!
Many thanks!
stifle
  • Substitutiary Locomotion
Re: Disabilities at WDW
« Reply #1 on: March 03, 2015, 10:19:43 PM »
Yes because of continuous abuse of the system the disability access in Florida is basically like an extra fastpass. The CM at the front of an attraction will basically look up the current queue time and knock 5-10 minutes off, and use that to calculate your return time.
twentythingamabobs
  • Zip-A-Dee-Doo-Dah
« Reply #2 on: March 04, 2015, 09:58:30 AM »
Ah that's not too bad then, I was worried that we would be given times hours and hours away and it would make it difficult to plan our days. Thanks Stifle  :D
